Wsparcie GUI-Generic dla ESP32
kurus
krycha88 pisze: wt mar 28, 2023 6:45 am
kurus pisze: pn mar 27, 2023 8:36 pm Próbuje postawić gui na takim module:
Wgrywam tak jak na załącznikach najpierw arduino szablon płytki, potem sam soft i niby wszystko ok błędów brak ale sieci nie rozgłasza :(
Spróbuj wgrać wszystko za pomocą
https://github.com/Jason2866/ESP_Flashe ... ag/v.1.4.1
Więc tak, jako że w esp_flasher nie można podać adresów jechałem każdy plik z pobranej paczki z gui po kolei i tak:
Dla plików boot_app0.bin i partitions.bin :
Using 'COM4' as serial port.
Connecting...
Detecting chip type... ESP32-C3
Connecting...
Chip Info:
- Chip Family: ESP32
- Chip Model: ESP32-C3 (revision 3)
- Number of Cores: 1
- Max CPU Frequency: 80MHz
- Has Bluetooth: NO
- Has Embedded Flash: NO
- Has Factory-Calibrated ADC: NO
- MAC Address: 60:55:F9:24:75:70
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
- Flash Size: 4MB
Unexpected error: The firmware binary is invalid (magic byte=AA, should be E9)
Dla bootloader_dout_40m.bin:
Connecting...
Connecting...
Chip Info:
- Has Bluetooth: NO
Uploading stub...
Running stub...
Stub running...
Changed.
- Flash Size: 4MB
- Flash Mode: dout
- Flash Frequency: 40MHz
Erasing flash (this may take a while)...
Chip erase completed successfully in 17.0s
Flash will be erased from 0x00000000 to 0x00002fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00014fff...
Flash params set to 0x0320
Compressed 11744 bytes to 8492...
Writing at 0x00000000... (100 %)
Wrote 11744 bytes (8492 compressed) at 0x00000000 in 0.3 seconds (effective 353.7 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 129...
Writing at 0x00008000... (100 %)
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.1 seconds (effective 367.1 kbit/s)...
Compressed 8192 bytes to 47...
Writing at 0x0000e000... (100 %)
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 524.6 kbit/s)...
Compressed 17104 bytes to 11191...
Writing at 0x00010000... (100 %)
Wrote 17104 bytes (11191 compressed) at 0x00010000 in 0.4 seconds (effective 357.5 kbit/s)...
Leaving...
Hard Resetting...
Hard resetting via RTS pin...
Done! Flashing is complete!
Dla GUI-Generic.ESP32C3.v6.0.4.bin:
Connecting...
Connecting...
Chip Info:
- Has Bluetooth: NO
Uploading stub...
Running stub...
Stub running...
Changed.
- Flash Size: 4MB
- Flash Mode: dio
- Flash Frequency: 80MHz
Chip erase completed successfully in 16.9s
Flash will be erased from 0x00010000 to 0x00128fff...
Flash params set to 0x022f
Compressed 11744 bytes to 8491...
Wrote 11744 bytes (8491 compressed) at 0x00000000 in 0.3 seconds (effective 339.2 kbit/s)...
Wrote 3072 bytes (129 compressed) at 0x00008000 in 0.1 seconds (effective 392.9 kbit/s)...
Wrote 8192 bytes (47 compressed) at 0x0000e000 in 0.1 seconds (effective 504.1 kbit/s)...
Compressed 1147232 bytes to 669547...
Writing at 0x00010000... (2 %)
Writing at 0x0001abac... (4 %)
Writing at 0x00026987... (7 %)
Writing at 0x000313a7... (9 %)
Writing at 0x0003d29f... (12 %)
Writing at 0x0004785d... (14 %)
Writing at 0x00050faa... (17 %)
Writing at 0x00057579... (19 %)
Writing at 0x0005e44c... (21 %)
Writing at 0x00064dfc... (24 %)
Writing at 0x0006b758... (26 %)
Writing at 0x00071de3... (29 %)
Writing at 0x00078146... (31 %)
Writing at 0x0007f044... (34 %)
Writing at 0x00085afc... (36 %)
Writing at 0x0008bc29... (39 %)
Writing at 0x00091adf... (41 %)
Writing at 0x00097725... (43 %)
Writing at 0x0009d609... (46 %)
Writing at 0x000a37e6... (48 %)
Writing at 0x000a9516... (51 %)
Writing at 0x000af684... (53 %)
Writing at 0x000b561b... (56 %)
Writing at 0x000bac1b... (58 %)
Writing at 0x000c0138... (60 %)
Writing at 0x000c58d9... (63 %)
Writing at 0x000cc08f... (65 %)
Writing at 0x000d1a95... (68 %)
Writing at 0x000d73b6... (70 %)
Writing at 0x000dd61d... (73 %)
Writing at 0x000e33a0... (75 %)
Writing at 0x000e9524... (78 %)
Writing at 0x000efb5d... (80 %)
Writing at 0x000f6104... (82 %)
Writing at 0x000fc3d6... (85 %)
Writing at 0x00102558... (87 %)
Writing at 0x001083f0... (90 %)
Writing at 0x0010ff94... (92 %)
Writing at 0x001161f2... (95 %)
Writing at 0x0011c6bf... (97 %)
Writing at 0x00122912... (100 %)
Wrote 1147232 bytes (669547 compressed) at 0x00010000 in 15.7 seconds (effective 586.3 kbit/s)...
Leaving...
Hard Resetting...
Po wszystkim takie logi:
Showing logs:
[09:32:59]E (124475) SPIFFS: mount failed, -10025
[09:32:59][124430][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:32:59][124430][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:03]E (128716) SPIFFS: mount failed, -10025
[09:33:03][128671][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:04]E (129216) SPIFFS: mount failed, -10025
[09:33:08]E (133171) SPIFFS: mount failed, -10025
[09:33:08][133126][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:08][133126][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:08]E (133448) SPIFFS: mount failed, -10025
[09:33:12]E (137433) SPIFFS: mount failed, -10025
[09:33:12][137388][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:12][137388][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:12]E (137710) SPIFFS: mount failed, -10025
[09:33:16]E (141652) SPIFFS: mount failed, -10025
[09:33:16][141607][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:16][141607][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:16]E (141929) SPIFFS: mount failed, -10025
[09:33:20]E (145925) SPIFFS: mount failed, -10025
[09:33:20][145880][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:20][145880][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:25]E (150219) SPIFFS: mount failed, -10025
[09:33:25][150174][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:26]ESP-ROM:esp32c3-api1-20210207
[09:33:26]Build:Feb 7 2021
[09:33:26]rst:0x3 (RTC_SW_SYS_RST),boot:0xf (SPI_FAST_FLASH_BOOT)
[09:33:26]Saved PC:0x40382096
[09:33:26]SPIWP:0xee
[09:33:26]mode:DIO, clock div:1
[09:33:26]load:0x3fcd6100,len:0x38c
[09:33:26]load:0x403ce000,len:0x6a8
[09:33:26]load:0x403d0000,len:0x2358
[09:33:26]SHA-256 comparison failed:
[09:33:26]Calculated: 4ab8657f6f5aa80b81c7dd649db3bd64a98999ed7c65acc5a2ab77ce80caf525
[09:33:26]Expected: 6babbc7b9ea63e04e0fc89ec224f6268aa3f84392018f73ab33721f768ce2eb6
[09:33:26]Attempting to boot anyway...
[09:33:26]entry 0x403ce000
[09:33:26]E (322) SPIFFS: mount failed, -10025
[09:33:26][ 278][E][esp32-hal-misc.c:128] disableCore0WDT(): Failed to remove Core 0 IDLE task from WDT
[09:33:30]E (4318) SPIFFS: mount failed, -10025
[09:33:30][ 4274][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:30][ 4274][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:30]E (4595) SPIFFS: mount failed, -10025
[09:33:34]E (8590) SPIFFS: mount failed, -10025
[09:33:34][ 8546][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:34][ 8546][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:34]E (8867) SPIFFS: mount failed, -10025
[09:33:38]E (12881) SPIFFS: mount failed, -10025
[09:33:38][ 12837][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:39][ 12837][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:39]E (13158) SPIFFS: mount failed, -10025
[09:33:43]E (17168) SPIFFS: mount failed, -10025
[09:33:43][ 17124][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:43][ 17124][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:47]E (21421) SPIFFS: mount failed, -10025
[09:33:47][ 21377][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:48]E (21921) SPIFFS: mount failed, -10025
[09:33:52]E (25932) SPIFFS: mount failed, -10025
[09:33:52][ 25888][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:52][ 25888][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:52]E (26209) SPIFFS: mount failed, -10025
[09:33:56]E (30218) SPIFFS: mount failed, -10025
[09:33:56][ 30174][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:33:56][ 30174][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:33:56]E (30495) SPIFFS: mount failed, -10025
[09:34:00]E (34511) SPIFFS: mount failed, -10025
[09:34:00][ 34467][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:00][ 34467][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:00]E (34788) SPIFFS: mount failed, -10025
[09:34:04]E (38785) SPIFFS: mount failed, -10025
[09:34:04][ 38741][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:04][ 38741][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:09]E (43025) SPIFFS: mount failed, -10025
[09:34:09][ 42981][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:09]E (43525) SPIFFS: mount failed, -10025
[09:34:13]E (47504) SPIFFS: mount failed, -10025
[09:34:13][ 47460][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:13][ 47460][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:13]E (47781) SPIFFS: mount failed, -10025
[09:34:17]E (51767) SPIFFS: mount failed, -10025
[09:34:17][ 51723][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:17][ 51723][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:18]E (52044) SPIFFS: mount failed, -10025
[09:34:22]E (56062) SPIFFS: mount failed, -10025
[09:34:22][ 56018][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:22][ 56018][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:22]E (56339) SPIFFS: mount failed, -10025
[09:34:26]E (60353) SPIFFS: mount failed, -10025
[09:34:26][ 60309][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:26][ 60309][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:30]E (64624) SPIFFS: mount failed, -10025
[09:34:30][ 64580][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:31]E (65124) SPIFFS: mount failed, -10025
[09:34:35]E (69102) SPIFFS: mount failed, -10025
[09:34:35][ 69058][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:35][ 69058][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:35]E (69379) SPIFFS: mount failed, -10025
[09:34:39]E (73443) SPIFFS: mount failed, -10025
[09:34:39][ 73399][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:39][ 73399][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:39]E (73720) SPIFFS: mount failed, -10025
[09:34:43]E (77751) SPIFFS: mount failed, -10025
[09:34:43][ 77707][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:43][ 77707][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:44]E (78028) SPIFFS: mount failed, -10025
[09:34:48]E (82050) SPIFFS: mount failed, -10025
[09:34:48][ 82006][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:48][ 82006][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:52]E (86359) SPIFFS: mount failed, -10025
[09:34:52][ 86315][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:52]E (86859) SPIFFS: mount failed, -10025
[09:34:56]E (90870) SPIFFS: mount failed, -10025
[09:34:56][ 90826][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:34:57][ 90826][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:34:57]E (91147) SPIFFS: mount failed, -10025
[09:35:01]E (95158) SPIFFS: mount failed, -10025
[09:35:01][ 95114][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:35:01][ 95114][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:35:01]E (95435) SPIFFS: mount failed, -10025
[09:35:05]E (99487) SPIFFS: mount failed, -10025
[09:35:05][ 99443][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:35:05][ 99443][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:35:05]E (99764) SPIFFS: mount failed, -10025
[09:35:09]E (103780) SPIFFS: mount failed, -10025
[09:35:09][103736][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:35:09][103736][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:35:14]E (108066) SPIFFS: mount failed, -10025
[09:35:14][108022][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:35:14]E (108566) SPIFFS: mount failed, -10025
[09:35:18]E (112569) SPIFFS: mount failed, -10025
[09:35:18][112525][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:35:18][112525][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:35:18]E (112846) SPIFFS: mount failed, -10025
[09:35:22]E (116856) SPIFFS: mount failed, -10025
[09:35:22][116812][E][SPIFFS.cpp:114] format(): Formatting SPIFFS failed! Error: -1
[09:35:22][116812][E][SPIFFS.cpp:89] begin(): Mounting SPIFFS failed! Error: -1
[09:35:23]E (117133) SPIFFS: mount failed, -10025
Sieci oczywiście nie rozgłasza..
rafalekkalwak@wp.pl
Użyj typu partycji: Huge App zamiast Minimal Spiffs
kurus
rafalekkalwak@wp.pl pisze: wt mar 28, 2023 8:19 am Użyj typu partycji: Huge App zamiast Minimal Spiffs
Po zmianie na Huge App w arduino i wgraniu poprzez esp_flasher pliku z gui sypie tymi samymi logami, a jak jescze później dograłem plik z bootloaderem to tak sypie logami ze zawiesz się esp_flasher..
Log z próby wgrania bootloadera:
Unexpected error: could not open port 'COM4': PermissionError(13, 'Odmowa dostępu.', None, 5)
[11:06:33]Expected: 12536e60caf530f96e6f214f11b12361719ad898ff41bc566062851d884dd795
[11:06:33]Attempting to boot anyway...
[11:06:33]entry 0x403ce000
[11:06:33]ESP-ROM:esp32c3-api1-20210207
[11:06:33]Build:Feb 7 2021
[11:06:34]rst:0x3 (RTC_SW_SYS_RST),boot:0xf (SPI_FAST_FLASH_BOOT)
[11:06:34]Saved PC:0x403d0f62
[11:06:34]SPIWP:0xee
[11:06:34]mode:DOUT, clock div:2
[11:06:34]load:0x3fcd6100,len:0x38c
[11:06:34]load:0x403ce000,len:0x6a8
[11:06:34]load:0x403d0000,len:0x2358
[11:06:34]SHA-256 comparison failed:
[11:06:34]Calculated: edbd6a9c34826c13595e85fdde1c072e6ea2e233a565e3ab32c1026ee24bad3b
[11:06:34]Expected: 12536e60caf530f96e6f214f11b12361719ad898ff41bc566062851d884dd795
[11:06:34]Attempting to boot anyway...
[11:06:34]entry 0x403ce000
[11:06:34]ESP-ROM:esp32c3-api1-20210207
[11:06:34]Build:Feb 7 2021
[11:06:35]ESP-ROM:esp32c3-api1-20210207
[11:06:35]Build:Feb 7 2021
[11:06:35]rst:0x3 (RTC_SW_SYS_RST),boot:0xf (SPI_FAST_FLASH_BOOT)
[11:06:35]Saved PC:0x403d0f62
[11:06:35]SPIWP:0xee
[11:06:35]mode:DOUT, clock div:2
[11:06:35]load:0x3fcd6100,len:0x38c
[11:06:35]load:0x403ce000,len:0x6a8
[11:06:35]load:0x403d0000,len:0x2358
[11:06:35]SHA-256 comparison failed:
[11:06:35]Calculated: edbd6a9c34826c13595e85fdde1c072e6ea2e233a565e3ab32c1026ee24bad3b
[11:06:35]Expected: 12536e60caf530f96e6f214f11b12361719ad898ff41bc566062851d884dd795
[11:06:35]Attempting to boot anyway...
[11:06:35]entry 0x403ce000
Serial port closed!
kurus
Znalazłem jeszcze to, choć mi to dużo nie mówi..
https://github.com/espressif/arduino-esp32/issues/6614
rafalekkalwak@wp.pl
A spróbuj flasha z Arduino najpierw. Pobierz SuplaDevice jako bibliotekę i masz od niej przykłady , zobacz któryś. To Ci załatwi układ partycji, a potem można próbować wgrywać sam soft pod odpowiedni adres pamięci.
Ustaw w Arduino:
Board : tu musisz dobrać pod ten wynalazek
UploadSpeed 115200
Flash Frequency: 40Mhz
FlashMode: DOUT
FlashSize 4MB
PartitionScheme: Huge App
To co znalazłeś to znaczy mniej więcej tyle ze firmware ma cos namieszane pod ta platformę i trzeba by żonglować wersjami żeby znaleźć działającą wersje.
Maniek913
Też miałem ten sam problem z tym modułem , (brak rozgłaszania sieci po poprawnym flashowaniu )Tak jak kol. wcześniej napisał pomogło wgranie dowolnego przykładu z biblioteki SuplaDevice poprzez Arduino IDE , a póżniej wgranie jednego już pliku z bulidera za pomocą ESP32Tool. Tu o tym pisałem:
viewtopic.php?p=148276#p148276
I jeszcze jedno: poczekaj cierpliwie - po flashowaniu moduł zaczyna rozgłaszać siec z pewnym opóźnieniem !
kurus
Maniek913 pisze: wt mar 28, 2023 3:18 pm Też miałem ten sam problem z tym modułem , (brak rozgłaszania sieci po poprawnym flashowaniu )Tak jak kol. wcześniej napisał pomogło wgranie dowolnego przykładu z biblioteki SuplaDevice poprzez Arduino IDE , a póżniej wgranie jednego już pliku z bulidera za pomocą ESP32Tool. Tu o tym pisałem:
Możesz napisać jak wybrać ten przykład z biblioteki supladevice? Wgrywałeś to na esp32c3?
Tak wybieram np. webinterface i pożniej i tak musze wybrać płytkę wziąć esp32 c3 dev?
kurus
Robert Błaszczak pisze: wt mar 28, 2023 4:39 pm Zrobiłem krótki filmik: https://naforum.blaszczak.pl/SUPLA/ESP32C3.mp4
Robert dziękuje za nagranie, po wgraniu jak pokazałeś mam takie logi:
Using 'COM7' as serial port.
Showing logs:
[19:02:16]ESP-ROM:esp32c3-api1-20210207
[19:02:16]Build:Feb 7 2021
[19:02:17]rst:0x8 (TG1WDT_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)
[19:02:17]Saved PC:0x40381a86
[19:02:17]SPIWP:0xee
[19:02:17]mode:DIO, clock div:1
[19:02:17]load:0x3fcd6100,len:0x438
[19:02:17]load:0x403ce000,len:0x90c
[19:02:17]load:0x403d0000,len:0x2358
[19:02:17]SHA-256 comparison failed:
[19:02:17]Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9
[19:02:17]Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19
[19:02:17]Attempting to boot anyway...
[19:02:17]entry 0x403ce000
[19:02:18]ESP-ROM:esp32c3-api1-20210207
[19:02:18]Build:Feb 7 2021
[19:02:18]rst:0x8 (TG1WDT_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)
[19:02:18]Saved PC:0x40381a86
[19:02:18]SPIWP:0xee
[19:02:18]mode:DIO, clock div:1
[19:02:18]load:0x3fcd6100,len:0x438
[19:02:18]load:0x403ce000,len:0x90c
[19:02:18]load:0x403d0000,len:0x2358
[19:02:18]SHA-256 comparison failed:
[19:02:18]Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9
[19:02:18]Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19
[19:02:18]Attempting to boot anyway...
[19:02:18]entry 0x403ce000
[19:02:19]ESP-ROM:esp32c3-api1-20210207
[19:02:19]Build:Feb 7 2021
[19:02:19]rst:0x8 (TG1WDT_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)
[19:02:19]Saved PC:0x40381a86
[19:02:19]SPIWP:0xee
[19:02:19]mode:DIO, clock div:1
[19:02:19]load:0x3fcd6100,len:0x438
[19:02:19]load:0x403ce000,len:0x90c
[19:02:19]load:0x403d0000,len:0x2358
[19:02:19]SHA-256 comparison failed:
[19:02:19]Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9
[19:02:19]Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19
[19:02:19]Attempting to boot anyway...
[19:02:19]entry 0x403ce000
[19:02:20]ESP-ROM:esp32c3-api1-20210207
[19:02:20]Build:Feb 7 2021
[19:02:20]rst:0x8 (TG1WDT_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)
[19:02:20]Saved PC:0x40381a86
[19:02:20]SPIWP:0xee
[19:02:20]mode:DIO, clock div:1
[19:02:20]load:0x3fcd6100,len:0x438
[19:02:20]load:0x403ce000,len:0x90c
[19:02:20]load:0x403d0000,len:0x2358
[19:02:20]SHA-256 comparison failed:
[19:02:20]Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9
[19:02:20]Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19
[19:02:20]Attempting to boot anyway...
[19:02:20]entry 0x403ce000
[19:02:21]ESP-ROM:esp32c3-api1-20210207
[19:02:21]Build:Feb 7 2021
[19:02:21]rst:0x8 (TG1WDT_SYS_RST),boot:0xd (SPI_FAST_FLASH_BOOT)
[19:02:21]Saved PC:0x40381a86
[19:02:21]SPIWP:0xee
[19:02:21]mode:DIO, clock div:1
[19:02:21]load:0x3fcd6100,len:0x438
[19:02:21]load:0x403ce000,len:0x90c
[19:02:21]load:0x403d0000,len:0x2358
[19:02:21]SHA-256 comparison failed:
[19:02:21]Calculated: a9753a4fc647c6545c1b919ef08db429130a48592727edca270f1e5a3da0d0a9
[19:02:21]Expected: 3bf6ef2cf3b9eefcd4b3c70cc5d1ce5138292d101a5cb1d5db6fbebf081b0a19
[19:02:21]Attempting to boot anyway...
[19:02:21]entry 0x403ce000
[19:02:21]
Serial port closed!
Następnie użyłem flash_download_tool_3.9.4 i wgrałem sam soft na adres: 0x10000 i po restarcie w logach pusto nic sie nie dzieje.. wifi brak..
Dodam że tasmota wgrywa sie normalnie z strony i tak samo po tasmocie w logach pusto, pozniej po dograniu gui jak wyżej efekt taki sam jak zawsze Formatting SPIFFS failed!
kurus
Robert wgrałem jeszcze raz i juz nie wiem czy coś zmieniłem czy jak i teraz finalnie po dograniu gui poprzez flash_download_tool_3.9.4 mam takie logi:
Using 'COM6' as serial port.
Showing logs:
[19:49:31][ 62015][E][WiFiSTA.cpp:232] begin(): SSID too long or missing!
[19:50:33][123371][E][WiFiSTA.cpp:232] begin(): SSID too long or missing!
[19:51:34][184729][E][WiFiSTA.cpp:232] begin(): SSID too long or missing!
Mam dwie takie same płytki na obu jest to samo jak cos...
Wróć do „GUI Generic”
