Jak wyzerować / ustawić wartość czujnika
shimano73
Koledzy znów potrzebuje pomocy
W sekcji setup mam
  if (ConfigESP->getGpio(FUNCTION_PLUVIOMETER) != OFF_GPIO && ConfigManager->get(KEY_PLUVIOMETER_FACTORY)->getValueDouble() > 0) {
      new Supla::Sensor::Pluviometer(ConfigESP->getGpio(FUNCTION_PLUVIOMETER),ConfigManager->get(KEY_PLUVIOMETER_FACTORY)->getValueDouble());
Jak nie trudno się domyslic jest deklaracja czujnika deszczu w mojej stacji pogodowej :D
Tak wygladaja biblioteki pluviometer.cpp
#include "Arduino.h"
#include <Time.h>
#include "pluviometer.h"
#define RAIN_NOT_AVAILABLE -1
namespace Supla {
namespace Sensor {
unsigned long currentRainMin;
unsigned long lastRainTime;
double cos;
double Pluviometer::getValue(){
	return _currentRainCount;
void ICACHE_RAM_ATTR serviceInterruptRain()
  unsigned long currentTime=(unsigned long) (micros()-lastRainTime);
  lastRainTime=micros();
  if(currentTime>500)   // debounce
     Pluviometer::_currentRainCount += cos;
	Serial.print("cos :"); Serial.print(Pluviometer::_currentRainCount);Serial.println("  +   ");
    if(currentTime<currentRainMin)
     currentRainMin=currentTime;
double Pluviometer::_currentRainCount = 0;
Pluviometer::Pluviometer(int pinRain, double rain_factory)
	channel.setType(SUPLA_CHANNELTYPE_RAINSENSOR);
    channel.setDefault(SUPLA_CHANNELFNC_RAINSENSOR);
    channel.setNewValue(RAIN_NOT_AVAILABLE);
	_pinRain = pinRain;
	_rain_factory = rain_factory;
	cos = _rain_factory;
 void Pluviometer::iterateAlways() {
    if (lastReadTime + 10000 < millis()) {
      lastReadTime = millis();
      channel.setNewValue(getValue());
  void Pluviometer::onInit() {
	pinMode(_pinRain, INPUT_PULLUP);
    digitalWrite(_pinRain, HIGH);
    attachInterrupt(digitalPinToInterrupt(_pinRain), serviceInterruptRain, FALLING);
	_rain_factory = cos;
};  // namespace Sensor
};  // namespace Supla
oraz pluviometer.h
#ifndef _Pluviometer_h
#define _Pluviometer_h
#include "supla/channel.h"
#include "supla/element.h"
extern "C" void serviceInterruptRain(void)  __attribute__ ((signal));
namespace Supla {
namespace Sensor {
class Pluviometer: public Element {
 public:
  Pluviometer(int pinRain, double rain_factory);
  static double _currentRainCount;
  friend void serviceInterruptRain();
  virtual double getValue() ;
  void iterateAlways();
  void onInit();
 protected:
	Channel *getChannel() {
		return &channel;
	Channel channel;
	int _pinRain;
	double _rain_factory;
	unsigned long lastReadTime;
#endif
I ta część działa prawidłowo i jestem z niej zadowolony, ale chciałbym mieć możliwość resetu pomiaru na żądanie lub w określonym czasie.
Niestety nie mam pojęcia jak powinna wyglądać składnia ustawiająca wartość np 0.
Proszę Was o pomoc.
Wróć do „Pomoc”
