ESP32 + LAN8720
elmaya
library for ESP32 + LAN8720.
Edited.
added the ability to select "I²C-address of Ethernet PHY" between 0 and 1.
paste the "esp32eth.h" library to your Supla library "\src\supla\network"
esp32eth.rar
(1.95 KiB) Downloaded 188 times
https://github.com/SUPLA/supla-arduino/tree/develop
 // LAN8720 Pin 10 connected to + 3.3v
#include <supla/network/esp32eth.h>
  Supla::ESPETH Eth(1);  // uint_t ETH_ADDR = I²C-address of Ethernet PHY (1)
 // LAN8720 Pin 10 connected to GND
  Supla::ESPETH Eth(0);  // uint_t ETH_ADDR = I²C-address of Ethernet PHY (0)
It is necessary to disable the 50MHz oscillator of the LAN8720 by bridging the oscillator pins 1 and 2.
the connections are:
------ESP32----------LAN8720
GPIO22 - EMAC_TXD1 : TX1
GPIO19 - EMAC_TXD0 : TX0
GPIO21 - EMAC_TX_EN : TX_EN
GPIO26 - EMAC_RXD1 : RX1
GPIO25 - EMAC_RXD0 : RX0
GPIO27 - EMAC_RX_DV : CRS
GPIO17 - EMAC_TX_CLK : nINT/REFCLK (50MHz)
GPIO23 - SMI_MDC : MDC
GPIO18 - SMI_MDIO : MDIO
GND : GND
3V3 : VCC
code example:
-(50MHz) Osc. Enable to GND -
GND                  : GND
3V3                  : VCC
#define supla_lib_config_h_  // silences debug messages
#include <SuplaDevice.h>
#include <supla/control/rgbw_leds.h>
  Supla::ESPETH Eth(1);  // uint_t ETH_ADDR = I²C-address of Ethernet PHY (0 or 1)
   Youtube: https://youtu.be/FE9tqzTjmA4
   Youtube example was done on older version of SuplaDevice library
#define RED_PIN              4
#define GREEN_PIN            5
#define BLUE_PIN             12
#define BRIGHTNESS_PIN       13
#define BUTTON_PIN           0
void setup() {
  Serial.begin(115200);
  char GUID[SUPLA_GUID_SIZE] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF};
  char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xFF, 0xFF};
     Having your device already registered at cloud.supla.org,
     you want to change CHANNEL sequence or remove any of them,
     then you must also remove the device itself from cloud.supla.org.
     Otherwise you will get "Channel conflict!" error.
  // CHANNEL0 - RGB controller and dimmer (RGBW)
  auto rgbw = new Supla::Control::RGBWLeds(
    RED_PIN, GREEN_PIN, BLUE_PIN, BRIGHTNESS_PIN);
  auto button = new Supla::Control::Button(BUTTON_PIN, true, true);
  button->setMulticlickTime(200);
  button->setHoldTime(400);
  button->repeatOnHoldEvery(200);
  button->addAction(Supla::ITERATE_DIM_ALL, rgbw, Supla::ON_HOLD);
  button->addAction(Supla::TOGGLE, rgbw, Supla::ON_CLICK_1);
     SuplaDevice Initialization.
     Server address is available at https://cloud.supla.org
     If you do not have an account, you can create it at
     https://cloud.supla.org/account/create SUPLA and SUPLA CLOUD are free of
     charge
  SuplaDevice.begin(
      GUID,              // Global Unique Identifier
      "svr1.supla.org",  // SUPLA server address
      "email@address",   // Email address used to login to Supla Cloud
      AUTHKEY);          // Authorization key
void loop() {
  SuplaDevice.iterate();
Nice :)
Finally something other than Arduino Mega with ethernet :)
elmaya
klew wrote: Thu Jan 13, 2022 9:28 am Nice :)
have you checked it?
You may want to complete the code with the options to select the gpio "EMAC_TX_CLK" between "ETH_CLOCK_GPIO0_OUT" and "ETH_CLOCK_GPIO17_OUT" in addition to the option to select "I²C-address of Ethernet PHY (0 or 1)".
with those options it would be more compatible.
I'm sure that you can make it very elegant and you can add it to the Supla library.
elmaya wrote: Thu Jan 13, 2022 9:52 am
I took a look at this code, but didn't really dig into.
I don't have that module, and with those various network interfaces I don't have enough "courage" to modify something without cheking it on HW :).
elmaya
okay.
I have been testing it for a couple of days and it works as it should.
We wait for someone else to test it.
elmaya
Example code for static IP.
  GND                  : GND
  3V3                  : VCC
// Set your Static IP address
IPAddress local_IP(192, 168, 1, 184);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
IPAddress primaryDNS(8, 8, 8, 8);   //optional
IPAddress secondaryDNS(8, 8, 4, 4); //optional
#define RED_PIN              4
#define GREEN_PIN            5
#define BLUE_PIN             12
void setup() {
  char GUID[SUPLA_GUID_SIZE] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
  char AUTHKEY[SUPLA_AUTHKEY_SIZE] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
     charge
  SuplaDevice.begin(
  ETH.config(local_IP, gateway, subnet, primaryDNS, secondaryDNS);
void loop() {
radzik_r
Fajne, przetestowałem, i działa.
Jeśli ktoś martwi sie zasięgiem wifi w szafie rozdzielczej to można już budować sterownik z potężnym mikroprocesorem i LAN
Cool, tested it, and it works.
If someone is worried about the range of wifi in the switch cabinet, you can already build a controller with a powerful microprocessor and LAN
dobo
Wyjaśnijcie mi sens połączenia tych modułów.
Ja widzę jedynie gdy mamy dużą odległość (100m lub więcej) do jakiegoś urządzenia, którym chcemy sterować poprzez połączenie z netem za pomocą LAN bo WiFi nie ma tam zasięgu.
Tylko koszty takiego rozwiązania kablowego są spore i muszą być przewidziane w instalacji domowej lub zewnętrznej (kabel LAN ziemny - żelowy). Tu rozwiązaniem mógłby być repeater WiFi na zewnątrz - było by taniej niż kabel LAN ziemny.
Czy LAN8720 w połączeniu z Arduino UNO czy NANO nie dał by tego samego?
Czy chodzi tu o moc obliczeniową ESP32?
Explain to me the sense of combining these modules.
I can only see when we have a large distance (100m or more) to a device that we want to control by connecting to the net via LAN because WiFi has no coverage there.
Only the costs of such a cable solution are considerable and must be provided for in a home or outdoor installation (earth-gel LAN cable). The solution here could be a WiFi repeater outside - it would be cheaper than a LAN cable.
Would LAN8720 in combination with Arduino UNO or NANO not give the same?
Is it about the computing power of ESP32?
elmaya
please in English.
uno, nano, don't have enough ram.
dobo wrote: Sun Jan 16, 2022 11:13 pm Explain to me the sense of combining these modules.
Arduino UNO and NANO doesn't have enough RAM to even load SuplaDevice on it (UNO has 2 kB).
Arduino Mega have 8 kB and it is enough to use it with Supla, however with 8 kB you can't do secured TLS connection (it takes at least 20-40 kB of RAM in order to load TLS library and to esablish secured connection with server). So neither of those will provide you secured LAN connection.
When it comes to ESP82xx vs ESP32 - well, ESP82xx are older and Espressif currently is developing ESP32 features. Most ESP82xx SDK changes are bugfixes only. It is a matter of time when those will be discontinued.
ESP32 has also bluetooth available and it seems that "smart device market" is going into direction of doing first device configuration/setup via bluetooth instead of Wi-Fi.
Wi-Fi vs Ethernet - you have to consider:
1. Security - Wi-Fi is usually encrypted but whole data is being transmitted on air, so anyone can listen. Ethernet requires physical access to cables to do the same
2. Air interface is in some places very crowded. In my previous apartment I was in range of dozens of Wi-Fi networks. Adding another Wi-Fi device doesn't help here.
3. Some people avoid wireless devices (i.e. in bedrooms) for health reasons (without going into discussion who is right or wrong). So Ethernet is a solution here.
4. When you need just single device in place of out Wi-Fi range, it may be better to install Ethernet there. It doesn't have range problems ;). Also it will take less power than Wi-Fi repeaters/APs + final device. You can power device from PoE, so you can use Ethernet cable for powering and communication. Think about gates, basements, etc.
Post Reply
