Supla universal IR emitter for 8 codes
elmaya
klimasstudio wrote: Fri Nov 19, 2021 2:35 pm I testet this:
https://en-forum.supla.org/viewtopic.php?p=66208#p66208
and this...
https://en-forum.supla.org/viewtopic.php?p=66412#p66412
and have same problems. I try flashing with others programs and modes and have same results :cry:
use this: https://en-forum.supla.org/download/file.php?id=15796
DOUT
8 Mbit
klimasstudio
Contact:
OK THX
Please send PINOUT for RX and TX diode on Wemos D1 mini ?
elmaya
klimasstudio wrote: Fri Nov 19, 2021 3:09 pm OK THX
same as in the first post ;)
klimasstudio
Contact:
Thanks to you. All working fine. Whats channel you prefer for use in cloud ?
elmaya
klimasstudio wrote: Mon Nov 22, 2021 6:48 am Thanks to you. All working fine. Whats channel you prefer for use in cloud ?
the type of channel that still allows adding enough icons. :lol: :lol:
ritual
elmaya wrote: Thu Apr 09, 2020 7:52 pm for 16 IR codes
All channels can be set as a light switch to contain 2 IR codes (SuplaX_On and SuplaX_Off) or for only 1 as a door opening (SuplaX_On).
IRController_16x_QIO_16Mbit.rar
Can we add temperature and humidity sensor to this?
elmaya
ritual wrote: Thu Mar 30, 2023 11:14 am Can we add temperature and humidity sensor to this?
I can't predict what effect adding a temperature and humidity sensor might have, I'm mostly concerned about the reception of IR codes.
What type of sensor would you like to add?
Hi @elmaya.
W
ill you be so kind as to modify your code for this device
michal1813
ritual
elmaya wrote: Sun Apr 02, 2023 4:44 pm
I am using this emitter to control my air conditioner remotely. So when I am about to reach home I have my room at a comfortable temperature. So with temperature sensor I can see if I have not left the AC on while I am at work.
Post Reply
